steering knuckle woes
jeepn-jason
Greensboro
I finally got the steering knuckle back from andy at crs and I have a problem. Seems that I have recieved someone elses knuckle because the taper on the tre is the wrong way. The one i sent to him had the tre going in from the top and the one I recieved goes in from the bottom. The reason this is a problem is because I was going to just install one highsteer arm for now and keep the tierod in the stock location. Should I taper these for rod ends?? Help me out guys. Thanks Jason
Jason,
That should have been the knuckle that you sent to me. If not, I will definitely correct it. We did 5-6 sets at the same time as yours and I apologize if you got it incorrectly. Give me a shout
704-525-5109
Andy
