- Mar 11, 2005
- Sanford, NC
Any tricks for removing stuck ball joints on a TJ? I got the upper out with a little effort, but the lower does not want to budge.
Maybe? Pass. side didn't budge but a tiny bit, driver's upper side moved up at least 1/8". I have that harbor freight tool, it worked for the upper.yager said:HF super special ball joint press and a BHF to help it along... I ended up needing heat on the last axle i did ball joints on...
was that causing your elusive death wobble?
I'll still need to replace my ball joints for that. I've heard that the high steer set up really cuts your turning radius down. Is this true?amcjeepman said:Rob, I still have the new high steer knuckles and most of the other stuff for the switch. I think we may need to get togather soon. Work has destroyed my free time this year but I am getting closer to being caught up. Only two Jobs left after this current one to fulfil promises from 2 years ago.
JB
