OBX Fisherman
- Mar 21, 2005
- Winston-Salem
I ripped out the long steel braided rear flex line on my XJ a few weeks ago at Dayton and replaced it with a short rubber line to get home. Works fine for the road, but I need to replace it with something a bit longer. I'm thinking about relocating the line to the top of the diff and re-doing the steel lines to the axle. The T-fitting on the axle is on the left side currently and by moving it to the top of the diff, it should not have to flex as much as before and less likely to be torn off.
Are the fittings on brake lines standarize, i.e. any 8" flex line will have the same size fittings as whats on my XJ? Since I'll be making my own steel lines I can use any fittings. Does anyone have any part numbers or application that use a long flex line, like from a 95 ford F250 for example, I can get from Napa?
Thanks
Gary
Thanks
Gary
