RatLabGuy
- May 18, 2005
- Churchville, MD
Help me not destroy my roof system
I have an upcoming engine-pull project and debating instaling an electric hoist on a sliding rail to use like a gantry in the garage. Bonus is later I figure it could be used for pulling / holding 4runner / Bronco tops.
The problem is my garage is attached to the house which is a single-story 70s ranch, and the ceiling joists / rafter ties are only 2x4s at 24" spacing with a standard V-truss support.. Not really joists, just the bottom cord of a truss. I have full access from the attic but they were never really designed for weight bearing.
And of course the joists run front-back of the garage. The total span of joists is something like 27' wall-wall, of that 21' is open garage space so that means if I had a sliding run, it would probably be 6-8' (front-back) and overlap with the centerline where the joists are tied together.
I would tie it directly to a joist, but I have no idea if it could support the load and assume it would need to be tied laterally to the adjacent beams to spread the load.
Is this just a terrible I idea I should give up on? Default is to just get a rolling hoist and chaulk this up to more reasons for a better garage.
Rough guess is the max load I'd have on the lift, including weight of the hoist itself is ~500 lbs.
I don't even know where to start with the math.
