Suspension leans to right after lift
RANDOMhero
chapel hill
For some reason my 97 4runner leans to the right in the back after installing OME 890 coils. Anyone know what may be the problem. Thanks for the help
If I'm not mistaken, they do that to offset the weight of the fuel tank.
Are the coils seated right??
if that is the case, maybe the springs are on the wrong side??? the tank is on the right isnt it?
If the front torsion bars were set differently it could affect the stance in the back if new rear springs were installed. This can be the issue if a slight lean is present. If it's got a bad lean then this is probably not the problem.
Just a little pimp lean. How much does it lean I think all jeeps do it not sure about 4runners
It's usually a problem with older springs, though... not new ones. You'll end up with a squat on the PS rear from torque transfer. That spring wears faster.
Nope, the one on my '97 4runner is on the left.
