t case ?
sportinanace
Kinston
was checking the fluid level in jeep wrangler T-case (231) and noticed some play in it moves from side to side I didnt know if it was suppose to be solid or should it have some play in it
what exactly has play in it?
the whole case will move from side to side slightly. I inoticed I when loosening the bolt to check fluid You can move it from side to side with your hands under moderate pressure. I just didnt know if it should move at all or not???
Sounds like your mount is wore out and needs replaced
