Where is it getting the fuel pressure reading from?
Holley told me i had to order a 0-100 pressure sensor. so i did
Also I remembered another input. I want to add another o2 sensor to the other bank
Dude, you need to read the manual.
Pin A31 on connector J1A is fuel pressure.
It's wired standard and doesn't use any of the programmable inputs.
Just like the IAT sensor is an input and doesn't use any of the programmable inputs.
In all cases you need a sensor that will output a voltage for the ECU to read, hence why you have a temperature sensor in the intake track for IATs and a 0-100 Holley pressure sensor for fuel pressure.
With a turbo you need the O2 sensor AFTER the turbo. Meaning AFTER the merge of both cylinder banks. Soooo both your O2 sensors will be reading the same value.
Also, 2 sensors is completely useless because the terminator X is unable to adjust fueling from bank to bank.
Just use one like everyone else, it's plenty fine if your tuner knows what he's doing. I've wired a 1000hp+ SBE LS on TermX and 2 O2 sensors were definitely not needed.
Edit: from reading the other topic, I would add a second fuel pressure sensor inside your surge tank in order to make sure that the lift pump isn't fucking up under load. I would also add an ethanol content sensor in order to make the tuning process easier and also enabling you to use pump 93 with reduced power in case you run out of fuel in the middle of nowhere and need to use what you can find at a "normal" gas pump.
I'm really not trying to dog you on this, but I do this shit for a living and before you start wiring stuff you need to really sit down and do your research or have a good conversation with whoever will tune your car, because turning cars around at the dyno due to poor wiring/lack of understanding of the electronics is something I see too often and it breaks people's egos and hearts when it happens. Nobody likes to hear "sorry I can't do what you're wanting because of (insert all the reasons you can think of)", but it happens ALLLLLLL THE TIME.
