95.5 Toyota Tacoma 4x4 2.7 Manual Trans
With the truck running the trans wont shift into gear..replaced clutch (whole kit), master cylinder, slave cylinder less than a year ago. if you try and crank the truck with the clutch in and in gear the truck moves...slave cylinder and master seem to be fine, only thing i can think of is teeth broke off the pressure plate????
Any advice, before i pull the trans?
