5100 Bilstein BE5-D558-TO up front, can use stock spring and raise the lower position on the Bilstein to get desired lift OR use a ToyTec (Eibach) 112-620 coils (bottom position on the Bilsteins this is a nice ride 3" lift )
if you're still on OEM ball joints, upgrade upper control arms to LightRacing 25460 uppers, uses adjustable position ball joints, lets you dial in caster and camber over stock, which becomes an issue as you raise the truck.
i haven't done this myself yet, but have driven one that has and is a nice ride,
Rear leaves can be modified adding a Wheelers add a leaf or replacing whole leaf pack, various vendors for them.
