- Mar 21, 2005
- Raleigh, NC
is anyone running the taurus fan setup as a pusher vs a puller type fan? If so whats your experiences with it.
I would think you would burn out the motor if you reversed the polarity to make it turn backwards. you would also have to flip the blade. A pusher will usually impede the flow in front of the radiator.
Do you not have enuff room to use it correctly?
Yeah room is the problem, we lack about a 1/2inch. Its an 84 cj7 with a fiberglass tub. We just put the M.O.R.E. engine mounts on it, and it moved the engine forward. There wasnt a way to move the motor back without modifing the mounts.
Run thru a ST85 NAPA relay and a block-mounted temperature switch.
