I am running a 1990 TBI junkyard swap on my 78 CJ5 AMC 304. My E200 is starting to make more noise than usual, I have seen where people suggest either, E8248 or GSL392, is the higher pressure a concern or ok? I only need 9 to 13 PSI these both are over 80. I don't have a regulator, unless there's one in the GM throttle body, i did run a return line thru my original return line, which is smaller than GM ran. Plus I ran the lines with the mind that I am not going to have over 15psi, so I may have leaks at the higher pressure which would be concerning obviously.
