rockcity
everyday is a chance to get better
- Apr 10, 2005
- Greenville, NC
I'm new to autos, so I'm a little lost on troubleshooting the TH350..
The TH350 is freshly built by a guy in Granite Falls. Can't remember the name. Same guy some of the BDB guys use for their transmissions... I'm also using the exact same torque converter Brandon (Rides) is using. Can't remember the stall right off hand...
While in 1st gear, 4wd high (or even 2wd) the trans feel very sloppy and doesn't seem to want to put any power out to the D300. If anyone can remember at The Flats race, the very first small rock hill after the start line, the buggy wouldn't even go up that. It wasn't a matter of ability, the trans wouldn't put the power to the ground. It acted like it was bogged down really bad.
I've checked fluid, its OK. Not really sure what to think is the problem. The engine (LQ4) has plenty of power and seems to be running great. The axles have 5.38 gears and I'm running 47" LTBs. The low gearing in the axles should be plenty for that engine with those tires.
I've pretty much kept it in 4wdL as it tends to have plenty of pickup there. But, the 4:1 in the D300 takes care of that.
I feel there should be plenty of power to at least make it up a small hill...
I can't even spin the back tires on the road and rarely can do it in the grass. It almost feels like the torque converter isn't locking up all the way or something.
Thoughts???
I really don't want to pull the trans out to trouble shoot until I have a good idea of what is the issue...
Thoughts???
