The “squirrel” part out
98yota
Statesville
This was the old squirrel 2.0 from out west
Link provided just to show the tube work. The rig was parted out a few years ago and the fellow I got it from was rebuilding it. I am going to take a step back from wheeling this year and focus on a c30 build I’ve been pushing off. Will post a parts break down, would entertain selling it whole but I know it’s probably better off in parts.
The current state it has a 19” belly, 6ft to the top of the cage, wheel base is 119”
-chassis, complete and wheeled for a few years, well structured, fuel cell, Holley fuel management, griffin radiator, seat mounts, dog house covers, link mounts, winch plate dash, etc $2500, $3k w/ WOD lower 2-1/2” link and ends and upper square tube links and ends
- new 8x6.5 raceline monster 17” wheels (can get b.s) w/ used 43” sticky sx that have been wheeled and heated up some cuts and marks from use $4000 for the set
-14” radflo coilovers (x4) new (150 over 225) $1500
- (x4) air bump stops $350 1 is missing the rubber bump
-new psc double ended ram, psc reservoir, ends, oribital, orbital steering shaft and lines $1600
-6.0 ls motor w/ 98k miles from a wrecked 2500, ict knock sensor delete, Holley ls car pan, standalone harness, factory computer non tuned, will included 2wd 4l60 $1500
-atlas 2 pass drop (will check gearing) w/ shifter handles and knobs 3k, will do $3500 w/ the adaptor and turbo 350
-art carr used shifter $220 with 2 consoles
-14 bolt rear 4.10 g80 locked, all new disk brakes, trussed w 4link brackets, pinion guard metal fabricated cover $500
- WMS Dana 60 front housing, new 4.56 gears, Detroit locker, 35 spline shafts, flat steering arms, ram mount, new rotors, new tmr caliper brackets etc, link mounts tacked on so that could be moved $1500
-WOD carrier bearing kit $420
-wilwood forward swing pedals $150 (new)
- 79 Toyota pickup rusty body for skins and a title $500 no frame or powertrain
If someone would be interested In it as a whole we could talk about it. I can text specific pics or videos of parts. Thanks 7044373151
(Front tires are off as I’m finishing mocking up the brakes)
