The Ruffstuff 9" Axle Housing!
Dan Fredrickson
Sacramento
This is it! The Ford 9" Axle Housing. This axle housing is a touch different than you are used to seeing from housing fabricators, this housing is not quite round! To put it simply, if it was round it would be weaker. The housing has 14 different facets to the basic diamond shape resulting from 36 individual bends! The end result is an axle housing that is the smallest shape possible and strongest shape too, AND there are no abrupt edges to hang up on passing rocks.
We make the Ford 9" Axle Housings to have 1/8" clearance of the ring gear because Ford made all ratio R&P's exactly 9" in diamerer. 3.08 ratios are 9" & 7.20's are still 9". Another beneficial thing to keep in mind when deciding on which axles you want to use is the NASCAR influence. NASCAR has been driving down the price of 9" axle parts for 50 years
They are available in 1 length (68") and you can cut them if you need shorter. They will come in 1 tube diameter and thickness but you can try and convince me that 3 1/2" x 3/8" wall DOM isn't strong enough. The Body of the housing is 1/4" A50 plate and the faceplate is 3/8 for better stud retention. They are internally reinforced with 6 seperate reinforcements that all tie together to make it way strong. You will also have the option of front or rear and left or right drop. We stock these so you won't have to wait either!
And they aren't that heavy either!
awww.ruffstuffspecialties.com_gallery_albums_userpics_10001_normal_Weightlifter_203.jpg
Actually, for a hot 19 year old model I think she really liked the housing:D
awww.ruffstuffspecialties.com_gallery_albums_userpics_10001_normal_Loren_20lean_20wrap_201.jpg
These are $575 . I think we can hold this price for a few months if steel dosen't do what it did last summer....We are just finishing up the truss options and I will add them later. The Toyota 8" is having a minor change done and then it will also be done! We will also make these for the Super 14 as Portal Tek makes them available.....
And now for Something completely different....
A removable third D60....We are making the housings for them...:thumbup
They are in testing and if all goes well look for them in 5-8 weeks....
Well lots of things have happened since I last updated this post.
We now make 7 different housings and have over 400 in use!
We build the Ford 9", the Toyota 8" & 9.5", the Solid 14 Bolt (removable third), the Sixty9 & Seventy9 (finally), and for export we build the Nissan Patrol!
We have spent alot of time working on new ideas for housings and building processes to make them stronger and faster to build. With our housings we don't offer you ateaser price for ahousing nobody would want, we only offer them the way we would want them. No 3" x .25" tubes, only 3.5" x .375" tubes.
We have been working with several companies to advance axle construction as we can and have several very interesting items in the pipeline. Keep an eye on our new product releases!
