- Mar 20, 2005
- Hendersonville, NC
1- Dynatrac Pro Steer ball joints and Dana 60 RCVs don't mix. No room for RCV boot with the massive upper joint. Oh and to top it off, there is no way to remove the $$$ upper joints without wrecking them.
2- Dynatrac won't give you the industry part # for the front wheel stud used in their 5 lug hub/rotor for a Pro Rock 60. FYI- A Dorman 610-277 is nearly identical.
3- RCVs and F450 knuckles are a tight fit too. Grab the grinder, die grinder and flap wheel unless you don't want to steer.
That's all. Just wanted to share...
