Thinking of converting to propane - Parts question
Blue70
Wilmington NC
I am thinking of converting a Ford 2 barrel 351M over to propane.
What size mixer and regulator should I get for this?
(I can get the vacuum lock out, hoses, and tanks etc from a friend I have at the fork lift dealer.. He just don't know how to size the mixer and regulator for my application)
Also.. do the propane setups just hook up and go, or do they have to be set up and jetted at first like a carb?
Thanks for any information you can supply
well the mixer uses a base off a carb for the adjustments.... most people run a Impco Model E regulator... and an Impco 425 mixer, but it is a 4bbl mixer
you could try propaneguy.com for some stuff.... and there might be some other threads on here about pane setups...
The two setups I've done were on Chevy 350s. Impco 425 mixer and Model E regulator to go with the VF30 lockoff valve. Pretty much hook up and go. I have a new, in the box never installed, 425, Model E and VF30 for $400 if you're interested.
