mbalbritton
- Mar 22, 2005
- Lakeland, FL
So, the saga continues on the 258.
I swapped the #5 piston and Also deleted the Mechanical Fuel pump in favour of an electrical pump. Now that everything is back together and (should) be ready, I cannot get it to fire. I am getting a bunch of backfires from the Carb while trying to crank. Starting from the beginning and walking through until now:
- Disconnected manifolds and pushed to the side, pulled gaskets
- Pulled Valve Cover, Rockers, Push rods, Head, Head Gasket
- Dropped oil pan, pulled #5 rod cap and popped the piston out the top.
- Closed up bottom end
- Cleaned up carbon build up in combustion chamber, wasn't all that bad really.
- Reinstalled head with new gasket
- Reinstalled push rods making sure they were seated in lifters, Reinstalled Rockers making sure they were seated on the rods and torqued to spec.
- Closed up valve train
- Reinstalled manifolds with new Gaskets.
- Confirmed TDC on compression stroke and Confirmed firing order.
- Plated off Mech Fuel pump hole
- Plumbed and wire new electrical.
Confirmed Fuel and Spark and compression on at least #1 and #3 with my finger plugged in the spark holes.
What could I have missed or accidentally done? I swear it's acting like a timing issue. But I have been over and over the firing order. Stuck my finger in the #1 spark hole and felt compression and confirmed #1 wire aligning with Dist. Button. We didn't mess with the distributor, but I did check and confirm that it's holding tight and not loose. I'm about to remove the Valve Cover to make sure all the rods are still in place and make sure there's no apparent issues in valve train.
Thoughts?
Thoughts?
