Tips on Removing XJ Doors
OBX Fisherman
Winston-Salem
Here's a few things I discovered the past few days while taking my doors off that may make your job easier when you decide to go doorless one day. This is one of the more difficult projects I had with my XJ. This pertains to the older style door hinge.
If your fenders are severely cut and you no longer have the inner plastic fender you can look in at the front side of the hinges from the wheel well.
In this pic (passenger side) the 4 arrows are pointing to the holes in the hinges. I bought a long T40 torx bit from Home Depot and attached it to several extensions and a universal joint on my ratchet. I was able to get the bit into those holes and seated in the torx head. I was able to break the torx bolt loose and then use a slack-jawed pliers to take the bolt the rest of the way out with the door open and supported. (see below)
I found using the extensions and universal joint was way too cumbersome so I came up with plan B which proved to be much easier.
Thats a craftsman T40 torx bit I ground 2 flats spots on to fit in a 5/8" wrench. If I put the socket in the ratchet the bit it wont fit on the 2 inner bolts due to clearence.
By closing the door and pinching the torx socket in the door jam I was able to keep pressure on it while turning it so the torx doesn't pop out.
Once the bolts holding the door were broke loose used a tow strap to support the door by the rafters in my garage...
...and used the slack jaw pliers to remove the bolts completely. I was able to lower the door to the floor by myself in a controlled manner.
Once the doors are off you may find your dog has discovered a new place to sleep!!
Now I'm on to fabricating some tube doors for the XJ!!
Gary R
BTW, riding around doorless is GREAT, now I know why so many people like the SWB jeeps!!
thats alot more complicated than i ever got with taking my doors off. 4 bolts and a wiring harness later, they are off in 10 mins.
Nah sawzall the bottem half hinge and it slids out like a wrangler door MUCH easier
[/URL][/IMG]
Tacoma747: once you get the Torx head bots out and door off you dont have to mess with them again. Ventilation was a big factor for this mod!!
Puma297: ZJs have a different style of hinge than the XJs, sounds like it's a lot easier!
theblueyak: No sawzall in my shop... yet! I used an angle grinder with a cutoff wheel to lop off the lower part of the hinges so my doors are now easily removable!
Gary R
Gary, that was a super write up, very detailed, complete with pictures for people like me. :lol: Do see "safari" doors in your near future ?
JB
JB
Safari doors before the Windrock trip next month I hope!! They will be especially nice at URE with the heat and Dayton this July! Wait, they will be nice ALL the time!!
Gary
Yes, good writeup, will come in helpful when I take mine off. Where did you get the latches for your tube doors. I also want to fab up some but not sure where to look for the latches. Thanks, Josh
I'm going to make my own latch for the tube door that will be integrated in the tubing. The upper tube running from the A-piller to the B-piller (the arm rest) will be notched at the end to slide over the mounting stud in the B-pillar. A smaller diameter tube which slides in the outer tube will secure the door around the stud.
Once it's finished I'll post some pictures, the latch should be really low profile and completely hidden.
Gary
