tire/lift question
jeepgeek2002
Columbia SC
would a 2" coil spacer boost + 1" BL on a Jeep Rubicon allow for 34x10.50x16 swampers? not for wheeling just for around town till i get the money for the lift.. lets say 2-3 months...and jeep is not a daily driver.
GEEK!
GEEK!
as long as the sway bars stay connected, you could get by...
I have 32's on a 2" BB...and it's "OK" for her street queen...
adding a 1" BL would clear tires that are only 1" bigger at the top...
and you're going from 31's to 34's, and adding 3" of lift in the process...
Greg
Yes. In that situation bump stops are the key. Disconnect the swaybar for droop and bump stop it properly to limit up travel.
it'll probably work on the street but you're probably gonna rub making tight turns and if you extend your bumpstops enough to prevent contact with your fenders you'll only be left with a couple inches of uptravel. i'm running the exact lift combination that you're talking about with 33x12.50's and i had to flatfender it to go offroad(got about an 1/8" left at full stuff between tire and fender, if that) but it works.
