Tire mounting and balancing
sharksanddanger
Reidsville
I need someone around the piedmont(High Point, Greensboro, Winston Salem) to mount and balance my 40" tires on some H2 wheels. I would prefer pad balancing and of course the cheaper the better. Ideas?
It may be a little bit of a haul but Galloways does pad balancing. Around $80 iirc.
balancing
I know you said you would rather have them pad balanced but Magnum puts out a tire balancing compound that it suppose to work better than Equal. Most tire stores should have access to it. You can look it up on line and see if its something you would be intrested in. Just a suggestion to save you from a long haul.
