Tire size Conversion chart
I just do the math on them. It's really easy and all the information is right in the size of the tire. Width is the first number, the second number is the aspect ratio (it tells you how tall each sidewall is as a percentage of the width), and then the rim size.
315/70-17
315 x .7= 220.5
220.5 x 2= 441
441/25.4= 17.36
17.36+17= 34.36" tall
315/25.4= 12.4" wide
Therefore it is a 34.4x12.4-17, just in case anybody was wonder how it was done. It's also pretty close with something like an 11.00R-16 Michelin. It's 11" wide and roughly 38" tall. 11x2= 22, 22+16= 38 :D
4LO.COM has a metric tire size calculator, a speedometer correction calculator, etc, etc.
It's pretty hard to beat this calc:
http://www.1010tires.com/TireSizeCalculator.asp
You can compare 4 tires, gives size, speedometer % difference, visual representation, tires made in that size, OEM tire sizes for vehicles, etc.
But on the fly, I just do the math.
As mentioned it's really simple:
315/75R16
315 is the section width in mm.
315mm/25.4 mm/inch= 12.4".
75 is the aspect ratio, so the sidewall is 75% of the section width.
0.75x12.4"=9.3".
Since obviously you have an upper and a lower sidewall, along with the 16" diameter wheel, you have
9.3"x2+16"=34.6".
So you have a 34.6" tall tire that is 12.4" wide and mounted on a 16" wheel.
Of course these are all just approximations, as each manufacturer will differ slightly.
For example, a BFG AT 315/75R16 is 34.6"x12.2" while the KM2 is 34.8"x12.3". A Nitto Terra Grappler is 34.5"x12.3" while the Trail Grappler is 34.8"x12.8". A Cooper STT is 34.5"x11.9".
