Tire Size Help
obxbronco
Elkin, NC
I know this may be a long shot, but i'm trying to find out what other size of tires would fit my 2012 Ford f-150 crew cab 4x4 truck. It has leveling kit on front too. Right now it has 275/55/20's but i could really use a taller size.
You can run a 35x12.5x20 with very minimal rubbing at full turn. No rubbing with a 1" spacer. That's what a buddy of mine has on his truck.
Make any difference if I go to 18" rim?
Only if the backspacing changes. I should have clarified that he is running a stock ford wheel.
The 20's are factory for mine, but so are the 18's
I've ran 305/65/18 BFG's in the past and now running 295/70/18 Toyo's on mine with a leveling kit with no issues.
think u could go bigger? or 305's pushing it?
They were big enough but BFG were the only ones making that size and were $$$$ as hell and only lasted 21k miles. Like the size of the Toyo's and have about 35k miles on them and still have a lot of tread left and have a 55k mile warranty to boot.
U wouldn't happen to have a pic do u?
Here is a buddy of mine with 35x12.5x18. He does not have any wheel spacers and they barely rub at full lock.
He just has a leveling kit.
Alittle bit slimmer tire wouldn't rub at all?
16 almost went 250 route but it does everything I've needed it to so far
Sliding back glass?
Na it has some useless trailer backup thing for people that don't know how to back though.
i make the back glass and the slider for the 16's and 17's.
Not sure. Try it! lol
If your worried about tire rubbing the a arm maybe go 285 75 my 12. 50s don't run but there's less than 1/4 inch of room
Ok thanks
