TJ Bolt in D44JK Axle Assembly
Cperry
Durham, NC
The TJ Dana 44 JK complete bolt in axle assembly is a perfect upgrade for the hardcore off road enthusiast. Don't waste money on your Dana 35 only to find out you need to upgrade again.
Benefits:
* Confidence in having a USA MADE OE 8.89 Ring Gear W/ Dana 60 size pinion shaft
* OE DANA SPICER USA MADE RING AND PINIONS AND CASTINGS!!!
* 3/8 WALL DOM TUBE
* Set 10 Wheel Bearings - which will retain the wheel if a shaft were to fail
* 35 spline Chromoly shafts - the upgraded shafts come standard
* Retains stock brakes to retain ebrake, or can be upgraded to a Disc brake set-up SET 10 OR SET 20 W/ Ebrake compatibility
* Stock Lug pattern 5x4.5 with the option to change to 5x5.5 whenever you choose
****NOTE: Disc brake Upgrade this is the most complete kit on the market. Brakes will be installed, Axle will bolt in and brakelines are already plumbed.
****NOTE: THIS HOUSING AND COMPONENTS ARE ALMOST 100% USA MADE AND IS THE STRONGEST DANA 44 AXLE ONE CAN BUILD, VERY CLOSE TO DANA 60 STRENGTH. THE OX AIRSHIFT OPTION IS THE EASIEST TO ACTIVATE AND STRONGEST OPTION(USA MADE). IT IS ALSO THE BEST VALUE AS YOU GET THE HD COVER WITH LOCKER PURCHASE!
http://eastcoastgearsupply.com/i-16...ssembly-semi-float-5x4-5-5x5-5-35-spline.html
That's a bargain. Comparable to the Dynatracs, if not better in some respects (shaft dia).
I should bring these axles I have back to you... let you guys put stock brackets back on them. :lol:
