Josh C
- Mar 21, 2005
- Wilmington NC
Looking to upgrade. Looked at the downeast kit w/ the 1ton TRE's and then looked at the WJ knuckle conversion. Anyone got any experience or pro's and cons or each setup
I had DEO's high steer set up and did not use it but once before ripping it off
I'd like to see a pic of it on level ground so I can get an idea of just exactly how much higher the tie rod is compared to stockAndy helped me out with my WJ conversion, he can def. fix you up. If you're ever up in Raleigh, feel free to come check it out or I could send you some pictures if you haven't seen enough on the internet.
