TJ LJ Rear Tail Plate Bumper
Barnes 4wd
Etowah NC
The TJ LJ rear Tail Plate Bumper provides maximum departure angle, two recovery points and adds rigidity to the back of your frame. These are made of 3/16” steal and the clevis mounts ore ¾” and accept a 7/8” D-ring. The Barnes 4WD Tail Plate Bumper ships welded and unpainted read for you to install
http://www.barnes4wd.com/TJ-LJ-Rear-Tail-Plate-Bumper_p_308.html
The Tj Lj Rear Frame to Bumper Tie-In Bracket is a great way to reinforce the tail plate of your Jeep. Don’t wait until you bend the rear frame cross member go ahead and get them in place before you next trip out. Also Rear frame tie-ins that do not have the weld in gusset are pretty much useless. Gusset will need to be welded to the frame tie in bracket. These are formed from 3/16” steel and are sold in pairs.
http://www.barnes4wd.com/Tj-Lj-Rear-Frame-to-Bumper-Tie-In-Bracket_p_317.html
The TJ LJ rear tail plate bumper provides maximum departure angle, two recovery points and adds rigidity to the back of your frame. Check them out here:
