JedGrant
- Mar 12, 2012
- Charlottesville, VA
Hey all, I’m getting some mostly coast noise out of the front D44 on my TJ. I installed a Nitro 5.38 gearset about a year ago and pulled it apart today to diagnose the noise.
Current specs:
Pinion+carrier preload is around 8 in/lb. Range according to Nitro is 6-9 (albeit only for the pinion).
Backlash is slightly high at 14 thou in a range of 6-10.
Wear pattern looks pretty good, coast side might be a little high on the heel but the drive side is in a good spot (photos attached).
Thoughts? I don’t mind pulling the carrier and checking the pinion bearings but I didn’t want to do this needlessly. Is the backlash too far out? Should I go ahead and double check pinion preload alone?
Wheel bearings are less than 2 years old and are tight. Am I missing anything?
Current specs:
