TJ slave cylinder bolts broke
Client
Member
Hickory
Went to replace the slave cylinder this evening after breaking it yesterday and both bolts are broke off. There is enough sticking out that pliers can get it the rest way out I've looked online to find where I can order em but no luck figure I'd go to home Depot or Lowe's tomorrow but I don't know how long there supposed to be
Should be 8mm x 1.25 thread pitch that stick out approx 25mm. If using bolts, 20mm long will do fine
OEM is studs, but you can use bolts too obviously
Left hand drill bit if you can't get it with pliers. Advance sells them now, as does hazard fraud. Though HSS, they are sharp & cut like a champ.
