Clubbs
- Jun 15, 2008
- Blounts Creek
Truck runs well with its new tune and a few less parts to breath through. Has this new phenomenon where is seems to get better mileage if I hold it down a gear now. Wasn't the case before and the trans tune is apparently set this way, but it can't make it's mind up between 5 and 6 at my usual 63mph cruise speed on my daily commute.
Rear end started to get some slop last year and now clacks and clanks with throttle off / on. Other than the noise I don't think it's a problem, all my other trucks have done the same and the poor beaten 14bolt in the CJ is horribly loose and still rolling.
Regardless, seems my factory 3.42's are holding the truck back some. Anyone running 4.10's on 35's with a tuned Cummins? Anything negative to be aware of? I imagine 1st gear will be all must useless unless towing, but based on current rpm to speed to mileage I think it will be happier with more revs and the trans tune will probably be better with this ratio too. Any thoughts?
