you should have brought it to me and you would be wheeling again
. It doesnt really matter how long it takes as long as it is right, the proper tools help alot. not one of them being a pinion depth tool you can measure and calculate all you want but the pattern is the proof, the original shim and expierence will tell you where and how far to go. 4 adjustments should be all you need on a more difficult install, usually 3, 1.stock shim, 2.make an adjustment beyond what you think the proper depth should be,3.back it off you have to be close now. 4. one final adjustment if you think you can make it better. If it takes more than 8 good long hours i don't care what kind of axle it is you got a cluster and your probably going to miss the good stuff like a perfect preload and pattern. Of course if its your first axle with not tools it can take a long time. if the shim is not behind the race with out the proper puller, pinion bearing damage is imminent, as with carrier bearings with shims under them. and set up bearings although usefull for getting close i have never used set up bearings and then installed new and not seen a noticable change, if using set up bearings i usually only use them for the 1st attempt, and then go to new, for final adjustments.
so anywho whats your problem post some pics and all the gear heros will get you squared away.
