Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
Ok . . . just noticed something, am curious, quote from Chevy High Performance Magazine in an article discussing Vortec Heads:
http://www.chevyhiperformance.com/howto/97458/index.html
Now searches on the web produce different online sources ie: forums/etc boasting as much as .480 lift clearance on stock heads
Lets say, just by the odd chance . . . completely theoretical
. . . that you have .488 lift on both sides of the cam
What symptoms would someone be able to recognize/look for as over cam lift problems to be?
Would perhaps your brand new engine progressively consuming more an more oil to the point its probably worse than a two stroke (Bout a quart every 5 gallons of Gas) yet still seeming to run just as powerful and without hiccup as when you first bolted it together, be a possible symptom? Or does that just still sound like rings?
This leads us to valvesprings, which require the most attention in a performance application. Since this is an OEM iron head, GM designed the valve guide to also serve as the inside diameter (id) locating device for the valvesprings. The guide’s large diameter acts like a sleeve that keeps the single-wire valvespring located >> properly. The guide is also machined at the top to mount a positive-style, 0.560-inch-diameter valve-guide seal. All of this conspires to limit total valve lift to a safe figure between 0.420 and 0.430 inch. The limitation is the clearance between the bottom of the retainer and the top of the valve-guide seal.
. . . that you have .488 lift on both sides of the camWhat symptoms would someone be able to recognize/look for as over cam lift problems to be?
