Top Fuel Dragster Info
StudNuts
Wendell
Found this on the internet and thought id share. Ive been to several ihra races and watched top fuel dragsters, it is just amazing how much power they have.
* The 500-inch Hemi makes more horsepower than the first 8 rows at Daytona.
* Under full throttle, a the engine consumes 1 1/2 gallons of
nitro per second, the same rate of fuel consumption as a fully loaded
747 but with 4 times the energy volume.
* The supercharger takes more power to drive then a stock hemi
makes.
* Even with nearly 3000 CFM of air being rammed in by the
supercharger on overdrive, the fuel mixture is compressed into
nearly-solid form before ignition. Cylinders run on the verge of
hydraulic lock.
* Dual electronic magnetos apply 44 amps to each spark plug. This
is the output of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro),
the flame front of nitromethane measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen
above the exhaust pipes at night is raw burning hydrogen, dissociated
from atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After
1/2 way, the engine is dieseling from compression-plus the glow of
exhaust valves at 1400 degrees F. The engine can only be shut down by cutting of its fuel flow.
* If spark momentarily fails early in the run, unburned nitro
builds up in those cylinders and then explodes with a force that can
blow cylinder heads off the block in pieces or blow the block in half.
* The engines twist the crank (torsionally) so far (20 degrees) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. But in reaching 250 mph well before 1/2 track, launch acceleration is closer to 8G's.
* Drivers must shut down before the finish line, or even dual
parachutes will not stop the car.
* If all the equipment is paid off, the crew worked for free, and
NOTHING BLOWS UP, each run costs $1000.00 per second.
