85TrailRunner
Member
- Mar 16, 2007
- Monroe
I'm in need of a metal cutting tool & was looking at the cost of a torch setup against a plasma cutter. Looking at NorthernTool's prices they got two plasma cutters that are in my price range & look to be able to cut the thickness of metal that I mainly work with. I figured a torch setup would be less expensive but by the time you buy a #3 oxygen cylinder, #3 acetylene cylinder, a torch handle kit with tips, then pay to fill the cylinder you're looking at around $650. For an additional $50 NorthernTool has a plasma cutter under their brand & for $800 Hobart has a plasma cutter with build in air compressor.
I'm not a pro & wouldn't be using it daily so it'll be for home/rec. use for weekend projects. What advantages does a torch setup have over a plasma cutter?
