ckruzer
Infidel
- Jul 2, 2015
- asheville nc
So...
At this point, while I am completing interior etc Im trying to plan the next next phase of the build so i can begin collecting parts.
This next phase, I am collecting a 4L trans, winters shifter, and depending on my Atlas fund either the atlas or a used adapter for the np231
The next next phase would be addressing my axles for final build status. Whether that is mildly upgrading what I have and sticking to 37 reds, or hardcore upgrading for 39.5 or swaping housings completely.
Anywho.
To really understand my options with my current setup Im doing a little math. So called, these stock 30 spline axle shafts are rated for 6000 some odd ft/lbs, while oem antique metallurgy 35 spline is rated for 8900 ft/lbs.
(Note: I have 79 f250 44/60)
So
300ish ft/lbs from the LS, by 3.83 first gear, by 2.72 np231 (possibly more with atlas), by 4.88 r/p ratio = 15,xxx ft/lbs.
Am I understanding this right? That even stock 30 and 35 are grossly unprepared for the torque multiplication in offroad environments? After market 30 spline would put me in the neighborhood of 10,xxx ft/lb rating, while aftermarket 35 spline would put me around 14k.
I feel like I am missing something.
Thoughts are welcomed!
My original plan and design and *want* was a 3/4 ton very capable offroad rig that could easily get ice cream or go to the beach whenever I wanted or drive to Harlan, have fun, drive smart, and fix a ujoint or shaft at most and drive home.
Ive looked up 44/60 hybrids and boring the 30 spline 60 to accept 35, but both routes will exceed a simple 500$$ upgrade per axle budget that I want. Exceeding it to the point it would be cheaper to sell the current axles and get "real" tons, which then also require the same budget to mildly mod out. Which still exceeds my original intent and budget
Anywho.
So
