Toyota 3.4L V6
marvilusone
Charleston, SC
I'm looking at buying a 96 Runner with a 3.4 V6, 5sp, 4wd. Just going to be DDing it. Has 187K on it. Are there any issues I should know about or need to look out for? I know the older 3.0 was almost good for nothing but a boat anchor but I haven't really ever heard anything bad about the 3.4. Thanks
3.4 is a much better engine than the 3.slow, they share very few if any parts, non interference engine if the T-belt breaks, replacing the belt isn't all that tough, lots of bottom end torque compared to most older Toyota engines.
if you can't verify maint. history, do the normal, belts, hoses, filters, clean the MAF, tighten valve cover bolts, change the spark plugs ( they are supposed to have dual electrode tips NOT PLATINUM )
if it is Auto, check the trans fluid, and disconnect the trans cooler from rad and install remote cooler ( rad. cooler will eventually crack allowing coolant into trans, which won't last long after.... search toyota boards for "strawberry milkshake" )
CV joint on rear shaft has probably never been greased, good luck
check rear brakes for gear lube intrusion, means the axle seal and bearing are shot, not too bad if you have half a clue and some know how ( I made a tool to remove the axle bearings from an old axle housing and some scrap steel )
Yea, 3.4 liter is MUCH better engine. Tons more power, good reliability. I've had 2 of them and really like them. I prefer the 5 speed to the auto, but my auto will smoke my buddys 5 speed. I guess it is all in how the engine is broke in. (Mine was broke in by a teenager) You won't go wrong with that truck provided it's been maintained. Like Voodoo says, check the basics.
