Bigben75ford
- Oct 4, 2007
- Asheboro,NC
Have lots of good Toyota parts I was collecting to build a Tacoma I had but plans changed and bought an 80series instead so it’s all up for grabs!
88’ Toyota rear axle 5.29 gears with spool. Chromoly shafts with disk brake setup. Diff armor, Bilstein shocks. 1.5” wheel spacers. $750
2002 Toyota rear axle 4:10 Elocker, fresh seals/bearings in diff. Axle has been disassembled but housing, axle shafts with brakes and diff all there. $650
2002 Toyota rear axle 5:29 Elocker(installed by ECGS) Diff armor,elocker motor guard. Full wiring harness with switch ready to go. $1200
Rear leaf springs can’t remember for sure brand but thinking All pro. 7 leafs, 52.5” eyelet to eyelet. Was used under 88’ 4Runner $275
2002 Toyota Tacoma A340F transmission with transfer case. Only 98k miles on unit, very clean and was hard to find in this condition. $700
Toyota rf1a gear driven 23spline transfer case. 4.7 marlin gears. Interlock pin removed to run twin stick shifters. $850(just the 4.7gears cost almost that themselves now)
Inch worm gear Tacoma Tcase adapter. I bought to use for my 2.7 with manual transmission but looks like on Marlins website it will work on 3.4 engine also(two sets of holes) all new hardware and seal adapter. $350
