I wanted to know if there is any difference in the toyota VSS from 92 and newer toyota trucks and cars.
I need a vehicle Speed Sensor (VSS) for my 97 4Runner 3.4l auto. I have a CEL and ABS light because I swapped axles and now need to pass inspection this month. The 4Runners used the ABS wheel speed sensors for the speedometer and I need a VSS to go into the t-case plus the 3 wire pigtail and some rewiring of the ABS computer to get the CEL to cut off. I found some info about swapping the Tacoma VSS into my T-Case and it is located on the transfer case of a 96-02 Tacoma but I think it is the same on 92 and on toyota cars and trucks that are non ABS. The thing is that I am having problems locating the exact tacoma (3.4l, auto non ABS) that the other guys are using.
Here is the ABS rewiring and speedo/MIL fix from Hunt4Steve
http://www.hunt4steve.com/99RunLtdDT.html
These photos are from IH8Mud
Here is what I need:
This is what my t-case looks like:
Tacoma VSS:
http://www.cougarfreakphoto.com/files/vss Marlin.jpg
Tacoma VSS:
