Bought a gooseneck crawler hauler last year, used it a couple times, rebuilt the hubs as part of proactive maintenance, then immediately decided to upgrade to 7k lb axles and 14 ply tires. Selling the axles, tires and wheels that I took off it.
(2) 5,200 lb axles with electric brakes and EZ-Lube hubs
95" hub face width / 80" spring perch width
Brand new Dexter bearings, races & seals
Brand new Dexter springs, u-bolts and spring plates - Springs are 3,500 lb each (7,000 lb per axle) and have new bushings
Dexter brake assemblies were replaced by previous owner and look to have plenty of pad life. Brakes may need some tinkering. They operate as intended and stop the trailer, but seemed to have some drag that I couldn't get fully adjusted out of them.
Comes with original equalizers that need new bushings, and possibly some minor welding/repair
(4) 235/80R16 Provider ST Radials mounted on 6-lug silver mod steel wheels and (1) spare wheel with no tire
Load Range E
Speed Rating 124/120M
3 tires are in good shape with lots of tread
1 is in bad shape - It holds air and got me home from AOP, but I would not recommend using it even as a spare
Comes with full set of good lug nuts
You just need to grab some spring bolts and a tire or 2, and you've got everything needed to upgrade your 7k car hauler to 10k.$1,000 $750 for the whole setup. Open to cash offers. Not really looking for trades. These are very much in my way. Located in Charlotte. I can bring them to the Not NC4x4 G2G where we can all make bad decisions together.
Load Range E
