- Mar 10, 2005
- Hooterville (24171)
I've read several threads on trailer brakes, but other than adjusting them, haven't had the pleasure (right ) of digging into them.
Brakes worked fine last month on a trip to Windrocks. Hooked to my trash a few weeks ago, adjusted the controller per instructions, but couldn't get the controller to turn red. Seems the wiring is correct or the lights (green = good connection & amber) wouldn't come on at all. Call Tenkosha (Voyager, not prodigy) and the lady said to connect the controller output to a test light and then to ground, manually energize, if red = controller is good or yellow = controller is fried. So it turns red which is good news (didn't exactly *want* to spring for a new controller), but also sucks because that puts the issue in the brakes themselves...
I read the recap from SN's issues and had a few questions regarding brakes & magnets. The last time I attempted to fool with them, I had the controller adjusted out to the point that the tr. brakes were getting energized w/ ZERO input to the controller... I went back and could hear them humming. Any chance this is a filth/dirt/shavings issue? Grounding issue? Or did the magnets just suddenly take a dump? Other thing(s) to look for past the visual wiring inspection and ohming the magnets?
Will hook it up and drag it onto level ground once the wife is awake for a looksee.
