Trailer build up is finally under way ( pics)
Discussion in 'Tow Rigs and Trailers' started by BRUISER, Mar 28, 2005.
  1. BRUISER
    BRUISER silent.. but deadly Moderator
    Mar 17, 2005
    Raleigh
    pic 2
  2. StudNuts
    StudNuts Well-Known Member
    Mar 21, 2005
    Wendell
    you sure you got the right axles this time :flipoff2:
  3. thecarman
    thecarman Well-Known Member
    Mar 17, 2005
    Apex, NC
    If only one axle has brakes, which should it be - the rear axle or the front?
    The front axle should have more weight on it, so maybe the brakes should go there?
    I don't know which one it is on my trailer - can look this weekend.
  4. lomodyj
    lomodyj Well-Known Member
    Mar 21, 2005
    Out in the Middle
    All the trailers I've ever seen with two axles and one with brakes, it's been on the rear axle...Don't know why...
  5. thecarman
    Mar 17, 2005
    Apex, NC
    I could see the rear axle braking being better for trailer stability. The farther rearward the braking force, the more it wants to keep the trailer straight in line with the tow vehicle?
  6. lomodyj
    Mar 21, 2005
    Out in the Middle
    Works for me!...
  7. junkman
    junkman Active Member
    Mar 21, 2005
    roxboro
    You should have run that channel the entire lenth of the trailor . It is still not a strong design. Your wheels will sit in front of and behind the channel. All your weight will be supported by the angle.
  8. BlueRidgeRunner
    BlueRidgeRunner Well-Known Member
    Mar 21, 2005
    Roxboro, NC
    Has Northern got axles for 45% off? I could use set of 5k axles.
  9. burley
    burley New Member
    May 31, 2005
    Wilmington
    money
    well if you like the build, i may know some guys wanting you to build them one too
  10. Rich
    Rich Asshole at large
    Mar 17, 2005
    Central PA
    IIRC, the rear... It has to do with the cantilever shackle unloading the front tires under braking (wants to rotate the front of the braked axle leaf down, which raises the rear of the idler axle, etc...)
  11. BRUISER
    Mar 17, 2005
    Raleigh
    Well it 95% complete
    all lights done, all wood on deck and bolted down...
    Only thing left is a little painting and tires :)
  12. BRUISER
    Mar 17, 2005
    Raleigh
    pic 2
  13. BRUISER
    Mar 17, 2005
    Raleigh
    pic 3
  14. BRUISER
    Mar 17, 2005
    Raleigh
    pic 4
  15. BRUISER
    Mar 17, 2005
    Raleigh
    pic 5
  16. rockcity
    rockcity everyday is a chance to get better
    Apr 10, 2005
    Greenville, NC
    looks good. Only thing I would have done different is either stagger the boards or get full length boards.
    Are those carriage bolts for the boards?
    FWIW, the nuts will come loose and you will have loose boards. Try nylock nuts or swap to self tapping (not self drilling) decking screws available at Grainger or Fastenal. Same screws used on tractor trailer flat beds to attach the decking.
    Rob
  17. BRUISER
    Mar 17, 2005
    Raleigh
    I am adding a secong but to each bolt so they can not come loose with lock tight :)
  18. thecarman
    Mar 17, 2005
    Apex, NC
    secong but = second nut??? :)
  19. BRUISER
    Mar 17, 2005
    Raleigh
    oops ... yes that is what i ment
  20. Motorman
    Motorman Member
    Mar 20, 2005
    Chapel Hill, RTP, NC, US, China
    NAXJA at Tellico
    cool, can i borrow it to go to tellico? week after 4th of July of Grant can go
  21. rockcity
    Apr 10, 2005
    Greenville, NC
    awesome. I had that problem with the nuts coming off no matter what I did, so I just use the decking screws now. They are much easier to install also.
    rob
  22. Wolfpack OffRoad
    Wolfpack OffRoad New Member
    Mar 21, 2005
    Trinity
    Do you think they would still back off if you used lock nuts? Not the nylon inserted ones. i can see how regular nuts would back off with the wood.
  23. BRUISER
    Mar 17, 2005
    Raleigh
    Well I will let ya know how it tows 1st :)
  24. rockcity
    Apr 10, 2005
    Greenville, NC
    The nylock nuts shouldn't come off, but the carriage bolts rust and when the boards are loose/old and you gotta remove them, they are a pain in the a$$. Re-check them everyonceinawhile...
    Good luck putting nylocks on carriage bolts without the heads turning. It can be done, but its a pain.
    Rob
  25. BRUISER
    Mar 17, 2005
    Raleigh
    what did you mean by stagger???
Share This Page
