Wes
- Oct 14, 2007
- Ridgeway, SC
Info:
Boat trailer with a 4 pin connector. I have brake lights, turn signals, and the rear running lights. My issue is with the side markers. The previous lights didn’t work so I installed new LEDs for the side markers only. I have 12 volts at each light, but they no workie. To rule out the truck I used an extra battery I had laying around and rigged up connections. Once again everything worked but the side markers. The only thing I haven’t done is removed and cleaned all grounds. A visual inspection doesn’t look like any bad grounds though. They’re all super tight. I’m at a loss. Any help or suggestions are appreciated.
