Danger_Ranger
- Jan 24, 2008
- Star NC
So I noticed today that the inside of my trailer tires are wearing much faster than the rest of the tire. But it's only on the rear axle. Any ideas? Bent spindle, or axle?
Mine was a bent axle. They over tightened the u bolt on one side.Mine did the same and was a bent spindle...
Mine is torsion axle and no idea how or when it happened. We rolled out for Moab and both rear tires blew, 1 before out of SC and 1 in GA. Replaced them and rolled on with no more problems, but the new ones had obvious wear on insides after the 4k mile trip.Mine was a bent axle. They over tightened the u bolt on one side.
That sounds like the trailer is nose high. Torsion axles are independent, so aren't capable of balancing load between the front and rear axles. If the nose of the trailer is high, the rear axle carries more of the weight. I'm not sure why they're wearing strangely - it could be a byproduct of deflection. The other possibility is that you just got unlucky and picked up debris in both rear tires (normal for any trailer to lose middle/rear axle tires at a higher rate), but that doesn't explain the uneven wear.We rolled out for Moab and both rear tires blew, 1 before out of SC and 1 in GA. Replaced them and rolled on with no more problems, but the new ones had obvious wear on insides after the 4k mile trip.
Trailer was dead level. I believe it was a combination of the bent spindle (which was confirmed after the trip) and defective tires. The tires were only two years old, but both rears blew (on the bent axle). I had two new Maxxis spares, so they went on the rear. We found a place to get tires and bought two new goodyears. I was swapping the original fronts for the goodyears to have all new tires and a cord poked me from one of the fronts, so they were about to go.That sounds like the trailer is nose high. Torsion axles are independent, so aren't capable of balancing load between the front and rear axles. If the nose of the trailer is high, the rear axle carries more of the weight. I'm not sure why they're wearing strangely - it could be a byproduct of deflection. The other possibility is that you just got unlucky and picked up debris in both rear tires (normal for any trailer to lose middle/rear axle tires at a higher rate), but that doesn't explain the uneven wear.
