McCracken
Logan Can't See This
- Jul 9, 2005
First off I have a 99 PSD if that makes a difference. the problem is that I'm not getting anything on the left (driver) side of the trailer. I checked the plug and it's not getting voltage either. I just went and picked up a new plug from Wally World. The plug was supposed to plug into the truck but the PO cut the plug from the truck and wired in a 4-pin connector instead of 7-pin. I cut his BS out and wired the 7-pin in. I'm pretty sure I wired it correctly. What sucks is that it was doing this before I installed the new plug and now it has the same problem with the new one. What gives?
If anyone knows about the back end of a PSD there's a plug above the spare tire and it leads to another plug that plugs into the new one I bought at Wal-Mart. Confused yet? Well, the only thing I know to do check the plug comign from the truck and see if it is hot or not. Any other suggestions?
One other note. He wired in a brake controller in the cab. Looks fairly neat but I don't know how that might have affecting the lights. Can it?
Thanks for all the help.
