TrailGear Dual Tcase help
Brownsxj
Durham NC
I own a 82 Toyota pickup and I'm in the process of putting in the dual transfer cases. The problem is the kit includes two little metal solid cylinders (.5" long, maybe .25" diameter) and a rubber seal that has a metal spring ring in it. I don't know what they do or go. If anyone has done the mod and can shine a little light, it would be very much appreciated.
I would call TrailGear but they are closed and I need to get this done tonight.
Thanks everyone
_Robb
Seal should be for your tranny output, and the other piece you are talking about sounds like what you need to weld on to your shift rod to keep your shifter in place. Hard to tell without some pics, but Last time i installed a doubler it seems that marlin had the best instructions. You may what to check out thier website instructions since install on on pretty much all the yota gear drive doublers is the same.
Duals
Thanks for responding Sullivan,
Unfortunately I can take any photos. I have the tab for the shifter already welded so its not that.
Still not sure what the two pieces are for... waiting on a few calls to return with a possible answer.
_Robb
