- Mar 20, 2005
- Morganton NC
OK I bought a 86 aerostar van for $100. Changes fluids, put tires on it.
Runs, drives fine. only one issue.
It has an auto OD tranny, I think the A4LD.And a 3.0 engine. You can count the shifts from a dead start, 1st, 2nd, Drive, and the OD. When at 70mph, it seems to be running to fast as in rpm's between 3000 and 3200. but, it never slips, always good pedal.
The biggest problem is that if you are cruising along at 70 mpg and let completely off the pedal the rpm's fall down to idle( around 600 rpm's)
When you get back into it, it's like you are in neutral. it won't re-engage until your speed falls down and it seems like it "catches up, engages, and then does fine.
Thanks in advance
Thanks in advance
