sharksanddanger
- Apr 18, 2005
- Reidsville
With my new project I've got to make some new mounts for my tranny, doubler and atlas. I've been researching quite a bit and the general idea is poly on the motor, poly on the tranny/t-case or rubber on the motor and rubber on the tranny/t-case. I'm going to build solid motor mounts with poly bushings and then I've got a poly mount from another truck that I think I may use for the tranny/t-cases.
This is my question. I'm afraid that with too many mounts I'll be breaking bellhousings or worse so I'm thinking about building a mount that bolts to the atlas and also to the bottom the tranny then centering the poly mount that I have dead center between the two. So I would have, two poly mounts on the motor, one on each side, the tranny and t-cases bolted together solidly bolted to a poly mount on a crossmember that bolts to the frame.
Ideas, thoughts, opinions?
