Tobers Well-Known Member Joined Jan 11, 2008 Location durham Feb 14, 2009 #1 5sp transmission on a 88 4runner. how do I tell if the fluid is full? how much should be in there?
Tobers Well-Known Member Joined Jan 11, 2008 Location durham Feb 15, 2009 #2 bump is there an online manual or something that would have this info? thanks
BrianGreen SSG Brian Green Joined Apr 5, 2008 Location Kings Mountain Feb 15, 2009 #3 I believe its on the driver side. there is a plug 3/4 of the way up. check it like a rear end. Remove the plug and stick your little finger in to the first joint and bend down. You should have a little gear oil on the tip of your finger.
