Transmission Jack
I don't have a floor jack that raises high enough. I can get it in without a jack, it will just make things a lot easier if somebody has one.
almost positive Jody T has one...but he wont be around this weekend..
i have one, but asheville is a little out of the way. when i used to pull them on the ground, i took and drilled a hole in the saddle of my jack and ran a bolt through the lug hole on the rim, it works really well. it also gives you 10" of lift(if your using a 10" rim). i should have maketed them when i was doing 205's on my back.
