transmission noise
CThurmond
china grove nc
i got a 2.5 l and a ax 5 trans
seems im geting a hissing or scraping sound from the transmission
i had the clutch replace recently
it got progressively louder yesterday ( over about 100 miles of travel)
i asked a buddy that knows a little about tech and he suggested it maybe a loose set of bolts on my flywheel
any imput would help
Could be. It could also be the flywheel rubbing against the bellhousing if the mouning bolts are loose(mounting the tranny to the block), or it could be the flywheel making contact with the starter if the shim wasn't put back in. And finally, it could be the release bearing/slave cylinder if it's a YJ.
Only while moving I assume, but does it do it in all forward gears or is it louder in say 3rd and 5th?
