Tradarcher
- Mar 20, 2005
- Creedmoor, NC
I have never had any problems with wobble with my 33" TSL radials and steel rims. I can run them up to 70 and drive with one hand. Been using them for 4 years.
I just put on some street tires today. 33" Sears Roadhandlers on Outlaw II rims. They are balanced with stick on weights only. They are perfectly stable and very smooth until I hit a dip in the road then the wobble starts. Doesn't seem to matter what speed above 30 or so. I even took them out on smooth highway up to 65 with no problems until I hit the offramp.
I rotated the two front tires with the same results.
There is equal pressure in them.
I carefully checked the toe and it's 1/8".
I took my steering stabilizer off and it appears to be in good shape. Can you check them by hand?
I don't know what my caster is but I think I remember making my adjustable LCA's an inch longer than stock when I installed my 4.5" shortarm.
I read this post about caster which seems to indicate that it is dependent on lift height and tire height. It was written by the engineer at nth degree who used to be a Jeep suspension engineer.
I measured the distance between the rear of my front tires and the front of my rear tires and there is a 3/8" difference. I don't know what this measurement is called but should it be equal? I guess to get it equal you have to lengthen the upper and lower control arms on the short side correct?
Any other suggestions?
