- Mar 24, 2005
- Stanley, NC
Is there anyway to go online and add weight or do you have to go to the tag office?
Add the GVW of truck plus the GVW of the trailer. I.e my 05 F250 is 9,800 lbs plus 18 ft deckover of around 15,600lbs. My tags are for 2,6000 lbs, which keeps me under CDL of 26,001 lbs. My tags were $413! The problem if you get pulled over is not actually being overweight on a particular trailer, its when you don't have enough tags to cover the GVW of the combination. That's when the DMV will tear you a new one.
That's how it is in S.C.
The weighted plate on my truck has to cover my GCW. So if my truck weighs "X" amount and my trailer weighs "X" amount, then you have to be tagged to cover for the combination of both of those weights. For example my truck weighs 8,500 lbs. full of fuel with driver and passenger, and normal gear. My trailer weighs 15,500 lbs. with two jeeps on it. I have to have a weighted tag rated for at least 24,000lbs. I'm actually rated for 26,000lbs.; Similar to Ashton, that is the most I can legally weigh or operate without needing a CDL, so figured I'd rate for my max.
Your use in NC may vary, but I've checked this out further than most, and this has been the answer from every department head in the state. Again, I cant tell you about NC.
I've got an 01 2500 chevy with the 8.1 gasser and i use to have a 12,000 pound tag and got pulled pulling my yoda and i was weighed at a little over 15,000 and got a $60 dollar ticket then i bumped up to a 18,000lbs tag but probably go back down to at least a 15,000lbs tag soon since the yoda shouldn't get any heavier
Doesn't work that way, CAT scales will you give you a date/time stamped receipt with a truck number and trailer number-keep in mind this is designed for commercial trucks- if you get pulled on that day and the cops scales are different then CAT will go to court with you and fight the fine. I'm sure if you load up your junk and take a time/dated photo to go along with your scale ticket then you are well on your way to avoiding a ticket in the first place. I ran commercial overweight (150,000+ steel/equipment) for 20+ years and ATTITUDE is a good 1/2 your battle when dealing with a revenue seeking Trooper..............Where can you fund a cat scale? Is there a way to document your weight with a given setup? Just to show a trooper if he claims you weigh more.
Sent from my DROIDX using Tapatalk 2
A 13k tag is ~$133, the next step up to 14k is ~$197.
I called the Tag office last week and was told 12K was ~$190. Have they gone up or can I hope that the person looked up the wrong figure?
So since an average backpacking pack is about 40 pounds, and you Toyota guys are convinced that your drivetrains are invincible, that leaves 1260lbs for beer. Thats 1680 12oz beer cans (ignoring the weight of the can of course).That leaves me with 1300# to play with (beer, camping gear, spare parts).
Nah, it wasn't that important to me.Did you do the conversion from fluid ounces to weight ounces?
